04-11-2013 06:55 AM
I have no experience about the speed of the communication, especially it is not important for this application. I allow some time (less than 100ms) to read the response after write, which is adequate to read all messages without losing data. I thougth this time lag is required whether due to speed of communication or execution speed of the controller (or both).
As a walkthrough I would convert the ExpressVI to subVI then use in the block diagram of the main VI. Thanks for your help and efforts for getting a solution to this problem.
04-12-2013 02:20 PM
I would allow more time like 300ms especially if speed is not important
04-30-2013 03:00 PM
What temperature chamber you use?
Now, i am working with a similar problem. i use a temperature chamber Cincinnati Sub zero, but i cant read and write data.
this brand had a Vis, that you could use for serial comunication. But the problem is that the communication doesnt work.
and i would like to connect with Ethernet and change de communication serial to ethernet. Whit this Vis i can establish a correct communication.
05-01-2013 08:33 AM
Can you see your instrument show up in device manager in windows and NI MAX?
05-02-2013 10:58 AM
Ok. When I conected the Termic Chamber (Instrument) to Ethernet port on the computer, the Led COM Flashing in the Chambe's Panel. And after I do a ping on the computer for I see the correct conection, this not show mistakes.
The MAX not detected the conection how show the attached document.
On the window "Enter the LAN resource details" show a mistake:
Could noy open a VISA session to TCPIP0::169.254.185.32::INSTR
Visa error code 0xBFFF0011
Insufficient location information or the device or resource is not present in the system.
when I treat to use "Manual entry a RAW SCKET " show a mistake:
TCPIP0::169.254.185.32::5900::SOCKET
This type of chamber had a libraries of VIs for connect the Chamber (Cincinnati Sub Zero) with VISA serial, but the problem is that the serial port doesn't work and the project is use the Ethernet for Control and Monitoring this instrument.
This VIs I do a little change in the Visa Open, change the dierction for:
TCPIP::169.254.185.32::5900
In all VIs that contain the Visa Port
05-02-2013 11:04 AM
I attach the Original Vis and the modified Vis.
when i run the Vis the principal mistakes that show are the next:
ERR(-1074001422) and ERR(-1073807331)
05-03-2013 03:14 PM
I apologize sincerely for the interruption, but I am trying desperately to get a USB-RS232 adapter, CommFront USB-RS232-1 to be recognized by VISA, MAX, Labview, any NI resource. It is recognized in Device Manager as "USB< >Serial." Bencizdim, how did you get the alien USB-RS232 to be recognized as a VISA resource?
05-06-2013 10:02 AM
If you're sure that the device is showing up in device manager, try going to tools<<reset configuration data. If this doesn't work then try and update MAX from our website by downloading and installing this update.
http://joule.ni.com/nidu/cds/view/p/id/3667/lang/en
05-06-2013 03:27 PM
Thanks for the reply.
05-06-2013 03:30 PM
Sorry, Ryan, I did not read far enough. I was eventually able to solve the problem last Friday, but as you suggested. I reconfigured the USB hub in Device Manager, and all was well, Thanks again for considering my quesion.
