For the most part, RS-232 and RS-485 devices use the same UART-based communication protocol (start, data, parity, stop, repeat). So the only thing you need to do to communicate with your RS485 device is install a RS485 COM port (RS485 is electrically different from RS232) or use an adapter to go from RS232 to RS485, and look up your devices communication settings (e.g. 115200,8,N,1).
