09-21-2005 01:21 AM
09-21-2005 11:04 AM
09-21-2005 11:07 AM
Do not know what a PCL-720 board is.
You need to know the command set for your chamber and the serial port settings (see the manuals). You could use Windows Hyperterminal to quickly send commands and get data back from chamber to test your cabling.
From there, search LV help for serail port examples, a basic serial read/write vi should get you there. You then need to execute the chamber execute command in a timed loop of 15 minutes duration
09-22-2005 12:29 AM
