Question on multiplex sampling / simultaneous sample & hold
Hello together,
I own a NI USB 6211 board which works very well. However I am trying to understand how exactly multiple channels are being converted from analog to digital. Therefore I drew two pictures with the way I understand multiplexing and simultaneous sample & hold. It would be great if you would check it and correct any errors I made
and
simultaneous sample & hold (?)
Can I find the exact conversion timestamp with the 6211 device?
Best regards
(3,487 Views)
Hello Lysandros89,
this could be helpfull
Setting AI Convert Clock Rate for the Longest Settling Time in DAQmx
with this properties you can read out the conversion times.
Additionally
Data Acquisition Sampling Terminology
This is an example between the difference for multiplex an simulaneous sampling how i tlooks like
best regards
Alexander
(3,469 Views)
Alright, thank you!
(3,417 Views)
