We are currently using an older computer running Win95 with a GPIB-PCII card to run about 12 DOS applications (written and compiled using Professional Basic). These applications communicate with six different pieces of equipment (scanner, DVM, etc.) via the GPIB card. To maintain consistency with our in-house network, we are being required to replace these computers with new computers running Win2000. However, we would like to continue using these DOS applications with minimal rework.
We have set up a test station with a new computer running Win2000 and we've installed a PCI-GPIB card along with the latest driver downloaded from your NI website. The driver software seems to work properly. After installing, the NI software can find and communicate with the instruments. Under the Tools option, I've enabled DOS support. I've also edited the config.nt file and edited the last line to unremark the "device=path\doswin16\gpib-nt.com" statement. Each of the DOS applications locate the instruments using an IBFIND(dev$,dev%) command where dev$="SCANNER" or "DVM", etc. To be compatible with the names, I've run GPIBCONF.exe and edited the GPIB0 template so that the device names match the instrument names used in the DOS applications (e.g. "SCANNER", "DVM", etc.). I've rebooted the computer after making these changes.
What I find is this:
1) If I edit the device names in the GPIB0 template using GPIBCONF.exe, then the address returned for each instrument in the IBFIND commands is -1.
2) If I run Professional Basic, load the source code, and change the instrument names used in the IBFIND statedments from "SCANNER", "DVM", etc. to the GPIB0 default names of DEV1, DEV2, DEV3, etc., then it works.
Question: Are there known issues with renaming the instruments in the GPIB template using GPIBCONF.exe for DOS applications? Do I have to use the default DEV1, DEV2, DEV3, etc. names in my DOS code?
