10-15-2015 07:55 AM - edited 10-15-2015 08:20 AM
Hi folks, I need help to understand what can i do with my oscilloscope.
Initially I wrote the DEMO program, provides with the Oscilloscope. With this I were able to acquire data by a channel.
Now I need to acquire more channels data at the sme time, beacause I have to:
- Trigger the signal;
- compare two different signal from two different circuits that are generated at the same time.
Can I do this? I report my demo.
Thanks for you help
10-15-2015 08:20 AM - edited 10-15-2015 08:21 AM
Thanks for you help
I don't care what your demo VI looks like.
Read the manual.
And I would suggest you take some LabVIEW tutorials and *learn* dataflow programming.
10-15-2015 08:36 AM
Thanks nyc.
I have just started to study about programming in LabView and I have a lot to do.
But what i wanted to understad is if i can query more channels by an oscilloscope at the same time.
Because if it is not possible, i will change software. I have not so much time to get results 😞
10-15-2015 08:59 AM
@GiuTemp wrote:
Thanks nyc.
But what i wanted to understad is if i can query more channels by an oscilloscope at the same time.Because if it is not possible, i will change software. I have not so much time to get results 😞
Which part of read the manual for the scope do you not understand?
10-15-2015 09:00 AM
10-15-2015 09:27 AM
Thanks a lot Dennis. My instrument is a RIGOL model DS1054Z. Yes, I've just searched for a driver and it works in sequence.
But the purpose of my work is acquire two signal at the same time. I'll take the memory directly by the oscilloscope for post-processing data.
However, Thanks a lot
10-15-2015 09:32 AM
10-15-2015 09:49 AM
If their driver uses a sequence. It is very poor LabVIEW programming.
10-15-2015 09:50 AM
@Dennis_Knutson wrote:
As long as both channels get triggered at the same time, then you don't have a problem.
Gee, he would actually have to read the manual to learn how to do this remotely.
What a concept?
