08-20-2012 06:31 AM
Hello.
I am new to vb6 and instrumentation.
I am trying to write a software that will control the HP4284A LCR meter using vb6. The meter is connected to the PC using a Prologix GPIB-USB controller. What I do is I first send the command to the controller ++mode 1, and ++auto 1 and ++addr X.
Then in order to control the LCR meter can you please tell me as to what I need to do?
Thank You.
08-20-2012 08:08 AM
kozxmartt wrote:
Hello.
Thank You.
Since you are using Prologix (not NI) and HP4284A (not NI), and VB6 (not NI), why are you posting here at a NI forum????
08-20-2012 08:19 AM
I meant to say Labview instead of vb6
08-20-2012 08:29 AM
08-20-2012 08:37 AM
Thanks, but are there any non ftp links, as Im unable to download from them.
08-20-2012 08:57 AM
That is a tutorial page for you to get started with LabVIEW.
08-27-2012 09:09 AM
I fairly know how to use Labview, but the main problem is this Prologix Controller. I have downloaded the drivers for the HP4824A. Since this controller makes the GPIB act as a virtual serial port, what changes do I need to make in the driver in order for it to work?
08-27-2012 09:35 AM
You need to get the LabVIEW examples from prologix.
08-27-2012 10:22 AM
I have the examples from Prologix too but the thing is that the HP4824A uses GPIB commands whilst the controller acts as a virtual serial port.
08-27-2012 10:54 AM
And what is confusing about the example? I see that for VISA you have to append a termination character for every write. I also see a compatibility layer for low level GPIB functions that you can download and do a search and replace if the driver does not use VISA for GPIB.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
