Hi, I'm having a bit of a problem getting my LeCroy LC584AXL oscilloscope to enter sequence mode via the GPIB drivers from the development zone. I have called the "config acquisition" and passed 1001 to it, which should set it to sequence mode. However when I use the "config sequence" function it generates an error saying "paramenter 3 out of range" which is elaborated as "incorrect acquisition type". I can't figure out what is wrong with the setup as I have got the other drivers to work with the 'scope, and the same error occurs when the function is initialised in simulation mode (ie without the 'scope attached). Any ideas/help will be gladly accepted!
PS
does anyone know how and who I'd conta
ct in relation to these drivers, was it NI or then manufacturer who wrote them?
