How are they incorrect? If you're using a LabVIEW graph to display the data, are you using the Initial X and x increment returned from the function? The amplitude array should plot correctly but the time scale won't be the same unless you modify something. You can either build a waveform data type with the correct t0 and dt or change the graph's properties.
