04-18-2014 05:11 AM
Hello everybody,
I have many instruments that I control with GPIB including the signal generator R&S SMG, and I can communicate with the SMG but after a time, MAX NI doesn't recognize it and I can't do anything with it in local mode, It doesn't respond to any button, so to control it, I must turn off the device and then turn on to control it in local mode, but NI MAX doesn't recognize it. But if I wait 5 minutes before turn on the device, MAX recognize it. So I am confuse and I don't know why it happens.
If you have a solution, it will be perfect,
Sorry for my english,
Flo
04-18-2014 06:08 AM
How many other instruments? Are you sure they all have unique addresses?
This sort of sounds like an issue with the firmware of your device. You should probably get a hold of R&S tech support.
04-18-2014 06:39 AM
Thank you for your answer
I have two others instruments, a spectrum analyzer which uses the adress 21, and a programmable filter which uses the adress 8, and the adress of the SMP is 21, so I'm sure they have unique addresses. I rensigner me if it is the firmware and I tell you if it is that,
Flo
04-18-2014 06:46 AM
Flo
Your spectrum analyzer and SMP are both set to 21? Those are not unique. I'm really hoping you made a typo there. Well, not really because that would be your problem.
04-18-2014 06:48 AM
No sorry for this mistake, the adresse for the SMG is 28,
Flo
04-18-2014 07:00 AM
I use a driver in LabVIEW which correspond to the driver of the SMH (R&S), maybe when I use this driver, there are a problem, but normally this driver is compatible,
Flo
04-18-2014 09:43 AM
Try swapping the GPIB cables.
Also make sure that they are connected securely.
