Problem of NI VISA driver configuration for Arduino R3 Uno
Good Morning, my name is Leong. Currently I have the problem of NI-VISA Driver configuration for Arduino. After I download the NI-VISA driver from NI website, I running NI-VISA drivers and select which type of hardware bus should I select. After I select the type of hardware bus, the NI-VISA prompt me to select the device ID that I have been installed, my device ID for Arduino R3 UNO is USB\VID_2341&PID_0043. I select my device ID and click the next button. I the click next button, the screen displayed as the below:
I choose to install the generated files on this computer and click finish. After I click finish, the error screen displayed as below:
May I know that what is the problem so I know how to solve the problem? Thank you for your kindness help.
Leong
(6,274 Views)
Accepted by topic author ArduinoProject
do not use the device driver wizard, just select the serial port you need in VISA
greetings from the Netherlands
(6,267 Views)
Thanks, Albert. I solved the problem based on your solution you provided. It works!
(6,258 Views)
You were not the only one who tried the hard way. The instrument driver wizard should start with the remark:
Are you sure that there is no driver available on the instrument driver network
and are you sure that a serial port that has a driver installed already does not need a driver made by this wizard?
(6,245 Views)
Dear Albert Geven,
Thank you for your solution provided to me. I connect my device with Labview, it works.
I realized that serial port that has a driver installed already.
Leong Yun Siong
(6,220 Views)
add other useful links, greetings
Getting Started With the LabVIEW Interface for Arduino
http://vishots.com/getting-started-with-the-labview-interface-for-arduino/
Ready to get started?
https://decibel.ni.com/content/docs/DOC-16204
(5,201 Views)
