NI Home
Cart Cart | Help
You are here:
Reply
ArduinoProject
Accepted Solution
Problem of NI VISA driver configuration for Arduino R3 Uno
[ Edited ]
Good Morning, my name is Leong. Currently I have the problem of NI-VISA Driver configuration for Arduino. After I download the NI-VISA driver from NI website, I running NI-VISA drivers and select which type of hardware bus should I select. After I select the type of hardware bus, the NI-VISA prompt me to select the device ID that I have been installed, my device ID for Arduino R3 UNO is USB\VID_2341&PID_0043. I select my device ID and click the next button. I the click next button, the screen displayed as the below:
I choose to install the generated files on this computer and click finish. After I click finish, the error screen displayed as below:
May I know that what is the problem so I know how to solve the problem? Thank you for your kindness help.
Leong
Trusted Enthusiast
Albert.Geven
Re: Problem of NI VISA driver configuration for Arduino R3 Uno
do not use the device driver wizard, just select the serial port you need in VISA
ArduinoProject
Thanks, Albert. I solved the problem based on your solution you provided. It works!
Trusted Enthusiast
Albert.Geven
You were not the only one who tried the hard way. The instrument driver wizard should start with the remark:
Are you sure that there is no driver available on the instrument driver network
and are you sure that a serial port that has a driver installed already does not need a driver made by this wizard?
ArduinoProject
Dear Albert Geven,
Thank you for your solution provided to me. I connect my device with Labview, it works.
I realized that serial port that has a driver installed already.
Leong Yun Siong
