04-02-2012 09:30 PM - edited 04-02-2012 09:32 PM
Good Morning, my name is Leong. Currently I have the problem of NI-VISA Driver configuration for Arduino. After I download the NI-VISA driver from NI website, I running NI-VISA drivers and select which type of hardware bus should I select. After I select the type of hardware bus, the NI-VISA prompt me to select the device ID that I have been installed, my device ID for Arduino R3 UNO is USB\VID_2341&PID_0043. I select my device ID and click the next button. I the click next button, the screen displayed as the below:
I choose to install the generated files on this computer and click finish. After I click finish, the error screen displayed as below:
May I know that what is the problem so I know how to solve the problem? Thank you for your kindness help.
Leong
Solved! Go to Solution.
04-03-2012 07:17 AM
04-04-2012 06:54 PM
Thanks, Albert. I solved the problem based on your solution you provided. It works!
04-08-2012 10:07 AM
You were not the only one who tried the hard way. The instrument driver wizard should start with the remark:
Are you sure that there is no driver available on the instrument driver network
and are you sure that a serial port that has a driver installed already does not need a driver made by this wizard?
04-10-2012 01:16 AM
Dear Albert Geven,
Thank you for your solution provided to me. I connect my device with Labview, it works.
I realized that serial port that has a driver installed already.
Leong Yun Siong
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
