05-12-2005 08:25 AM
05-12-2005 10:48 AM
@MSARIKOC wrote:
I use Labview to control a test machine. There is an 6251-M series DAQ board for analog signals to be acquired and PCI 6509 for Digital I/Os. I also control an AC motor drive via serial port(Enable, start, stop and speed ref.). The problem is after testing an amount of products(e.g. 100) the cycle time of the test increases(from 10sec to 20-30-50sec). I saw that this caused of misreadings from serial port(because I read the speed via serial port to switch between steps). Why it doesn't happen at first and starts after making an amount of tests. What can I do about this. How can I make sure the readings to be the same everytime? And make the cycle time fixed.
05-13-2005 03:10 AM
05-13-2005 03:56 AM
@MSARIKOC wrote:
Do you think this effect the serial port communication only. Because the other process is working fine, only the serial port communication have problem.
