Hi Ross,
thanks for the help and answer.
Yes, I can see the Device and Interfaces in MAX.
No, scanning does not work because it never completes. I have to kill the task after couple of hours manually.
I am also sure that at least one of the used interrupts (3, 5, 7, 10, 11) is not further used by any other device. I also switched off all devices in the PC bios (serial line, parallel port, audio, usb etc.) and also removed all unneccessary cards from the computer.
I have no other idea ...
Ross, do you have some more low-level debugging tools or a debug driver (which reports to Dbgview.exe) to figure out the reason for that??? Is it possible that your driver has problems with the Ricoh PCI2PCMCIA bridge chipset?? Is it essentially that t
he GPIB driver needs an interrupt? ... I guess, polling would also work??
Best Regards,
Heiko
