Was the other card you tried also a National Instruments PCMCIA-232/2 that worked, or was it a completely different PCMCIA card? If it is the same card, your original card probably needs repair. If not, you can try the PCMCIA card in a different system to test the card itself. If you think you need to send the card in for repair, you can contact the Applications Engineers to arrange it.
