Hello rann,
I am assuming here that you only have one PCI-6030E (formerly known as PCI-MIO-16XE-10) card & one SCXI chassis and you use this combination with multiple computers.
You also mentioned that you checked your MAX settings on this computer with this card and they look good. Are you able to detect, configure and test the card in MAX successfully? If yes, and then if still the computer freezes, you might check a few things to determine where the problem is:
Does this computer freeze in any other cases apart from this application? or in this application with lower data-acquisition rates?
Is this computer from a comparable generation as the other machines that you are using? (processor, speed, etc) Did you check if any BIOS updates are re
quired for this computer?
If you can not configure the card in MAX, did you try using a different PCI slot on this computer (it might be possible that one slot is bad)? Is it there in the system device manager?
In case you have more than one PCI cards,did you try using a different PCI card with this computer? Does this second card freeze this machine as well?
If you use the first card (the one that freezes the machine) with another computer, does this card freeze the new computer as well?
These should help you narrow down to see where exactly the problem is (card or anything else). Good luck !
