11-12-2013 11:14 AM
I have used 2 kinds PCI-GPIB (one from Agilent, and other from Ni); I have create looping software to acquired the testing data from spectrum Analyzer.
with both computers one with Agilent, and other with Ni PCI GPIB, I have found out that Agilent PCI-GPIB computer continue running looping find forever; but Ni-PCI-GPIB
computer is failed to acquired the data after 37xx loops count. Is any one have any idea what configuration that I need to change at the driver level to remove this limitation?
One more for notice: I have used WindowsXP service pack 3 for both computer with Dell Optiplex GX520. Everything else loading the same driver.
I have duplicated the same failure all the time from Ni-PCI-GPIB computer; it responses null data.
Any suggestion will be appreciated.
11-13-2013 02:56 PM
What do you mean when you say the computer failed to acquire the data? Does your program produce an error?
04-30-2015 06:14 PM
I have the same problem the GPIB-Read function lockup after 25 successful reads
05-01-2015 06:55 PM
Hi labview-PA,
For further troubleshooting, it would be great to know about the device you're are using, any errors you're receiving, and your software configuration.
I also noticed that this is an older thread. You may receive faster support from the NI Community if you create a new thread!
