On Sat, 15 May 2004 20:23:58 -0500 (CDT), SQP Products wrote:
>PCI-GPIB does not like returning from computer power-save mode. I
>need to restart the application. Uggh! Customer not happy.
>It seems volatile memory is lost on the PCI GPIB Card. When the
>system returns from power-save, I cannot get to my GPIB instruments.
>I have to close the application and restart it. I've tried
>unregistering and reregistering the gpib globals and resetting the
>device interfaces (reissuing the ibdev command) without luck. I am
>using Visual Basic 6, but I also get the Measurement and Automation
>Explorer to fail in the same way, so I don't think it is my
>development environment.
Can you change your power save settings? What operating system
are you running?
Also, some BIOS's have options for power save. For example, recent
IBM's can be set to maintain power to all peripherals, or only to main
memory. Of course, you would want it to maintain power.
I suspect the GPIB board and its driver are completely unable to
handle power save operation. It probably was never considered while
it was being designed.
Aidan Grey
