10-27-2015 12:28 PM
Hello All,
I am having the same problem and did the changes mentioned in this post, but they didn't work. IX2-BSW program is working and I tracked the serial commands being written and read. An example is:
write:
32 50 4F 53 3F 0D 0A |
2POS?.. |
read:
32 50 4F 53 20 33 35 30 30 30 0D 0A |
2POS 35000.. |
However,
1.NI Max test panel gives Read problem error from the test panel
2. Olympus Command VI gives read error as well, when I enter a command (actually the same command with the first message of this topic:
2POS?\r\n
Since I am new to Labview, I tried everything I found on internet:
1. I changed the COM port settings as in this link and checked from msdos-->MODE if they are really changed:
https://micro-manager.org/wiki/Olympus
Or specifically:
Baud rate: 19200, data bits:8, parity:even, stop bits:2, flow control: RTS/CTS
2. I increased and decreased the timeout time, did not work
3. I am doing everything after restarting the computer again, to be sure.
4. I changed the command string's display property to backslash first, did not work,(which is the same write code written above), I checked it from the serial port monitor:
31 32 50 4F 53 3F 5C 72 5C 6E
It basically adds '`1' or '`31` in hexadecimal, this is coming from the Device number input in the program. Device no is concatenated to the message
5. .Then I changed the command string's display property to hexadecimal, the same thing happened, a '`1` is added
The device number string is going to two concatenation objects. It (reasonably) adds 0 to the message when I make it 0. It gives error when I remove this from the block diagram, because concatenation wants another input.
What do you suggest me to do? Since there are other inputs to the object, I don't want to change it. I am assuming there is something I might be missing, any help is appreciated, I attached thescreenshot.
Regards
10-28-2015 05:07 PM
Hi StressedGradStudent,
When you query the device in MAX VISA Test Panels are you sending what the device expects according to the User Manual for the microscope?
Also, I would strongly recommend creating a new thread to increase traffic looking at your issue rather than adding on to a solved thread.
Aaron F.
Applications Engineering
