04-17-2017 07:16 PM
I am trying to make a simple serial read vi but facing a problem that all the data serially coming are not getting separated and getting the plot on the same graph. I m using comma delimiter still not able to separate the data.
The format of coming data :-
Serial.println("95336");
delay(1000);
Serial.println("36.2");
delay(1000);
Serial.println("526.23");
delay(1000);
so on .
I have added the screenshot of my VI
please help me out
Solved! Go to Solution.
04-17-2017 08:15 PM
You are using Println which separates your date with linefeed characters. Your LabVIEW code is expecting a comma separator.
You need to either do 3 VISA Reads in LabVIEW, or better yet, do a single Println in your C code with the data separated by commas.
04-17-2017 08:44 PM
thank you so much it worked
now I am trying to plot
Serial.println("$,2232,32.23,96534,826.2232,8,58,3,-19.2,38.6");
delay(1000);
Serial.println("#,4562,56.53,78965,25.23,25.6,58");
delay(1000);
this where $ and # are starting checking symbol of the whole data whether it is correct value or garbage one
if $ or # is found than only it will plot
