01-15-2015 08:15 AM - edited 01-15-2015 08:16 AM
I am controlling two output channels of E3631A power supply. The voltage and current are defined in csv file and then the labVIEW will read from the file and control the E3631A. However, after some time the labView will always crash and then display the error shown below. Does anyone know what the error means and perhaps the solution?
Thank you in advance.
01-15-2015 09:00 AM
01-15-2015 10:26 AM
The whole content of the files are read once before entering the loop and put them into array. Then I use some logic blocks to step through the voltage and current from the first column, second column, until the fifteenth column. It will then re-start from the first column. I have included the files and code that I use inside the zip file.
01-19-2015 03:15 PM
