Ni cRIO 9035 not supported in labview 2014
Hi all ,
 I would like to ask whether Ni Crio 9035 is able use in Labview 2014 ? What is the possible reasons that this error is showing that Device is not supported in Labview enviroment . Currently the hardware Ni Crio 9035 able to establish connection in Labview 2015 but not labview 2014 .Hence , is it possible i get a confirmation that the following hardware Ni CRIO 9035 is supported in labview 2014 and detail solution steps if possible .
Regards ,
Jeremy
(3,694 Views)
Hi Jeremy,
The minimum of required software/driver version for cRIO 9035 as follow:
1. LabVIEW 2014 SP1 or later
2. LabVIEW Real-Time Module 2014 SP1 or later
3. LabVIEW FPGA Module 2014 SP1 or later1
4. NI-RIO Device Drivers February 2015 or later
** Reference: http://www.ni.com/pdf/manuals/376935c.pdf
2014 is the prior version of 2014 SP1, the reason why it is not supported to be used with cRIO 9035.
Hope this explanation helps.
Nur Laila
(3,656 Views)
Thanks a lot , it works now  .
(3,625 Views)
