Need help on USB-8451 Error -301743
Hello Masters of LabVIEW!
I am making a test system for a proximity sensor.  I'm quite new in this HW and I2C programming that's why I have no idea what to do to solve my problem. At first, I get error -301742:
Possible reason(s):
NI-845x:  The slave did not acknowledge an address+direction byte transmitted by the I2C master. Reasons include the incorrect address set in the I2C configuration r the incorrect use of the 7-bit address. When entering an address to access a 7-bit device, do not include the direction bit. The NI-845x Basic I2C API internally sets the direction bit to the correct value, depending on the function (write or read). If your datasheet specfies the 7-bit device address as a byte, discard the direction bit (bit 0) and right-shift the byte value by one to create the 7-bit address.
But after I enterd the correct address,  I get error -301743:
Possible reason:
 NI-845x:  The slave did not acknowledge a data byte transmitted by the I2C master.
Anyone there know how to approach this problem?? Please help me..
Thanks to all for your time!!
(4,329 Views)
(4,321 Views)
Did you ever figure this out? I am having the exact same problem. After I put in the correct address it is giving me the -301743 error.
(3,529 Views)
