NO VISA resources found using MAX but VISA Interactive Control OK
Greetings,
I am using Keysight  USB 82357B GPIB and using MAX to find the device
under the Configuration -> Devices and Interface. But it shows
"NO VISA resources found".
But when I used the Keysight connection expert it shows all the devices.
I've cheeked the NIVISATulip.dll:and have enabled the Agilent GPIB cards for 488 program in the keysight connection expert.
Does anyone know why ?
Thank you and best regards,
Nelson
(3,256 Views)
I updated the NI-VISA from 16.0 to 17.0 it fixed the problem of the no visa resources found.
But now either in the MAX or using a Vi it does not shows the resources names of the equipment I connected trough the USB to GPIB converter.
(3,207 Views)
Hello NES2112!
I have a couple of questions.
- What is the version of LabVIEW and the OS that you are using? In order to check that driver VISA is compatible with your systems.
- Have try to check with the Scan for Instruments?
Regards.
(3,126 Views)
Hello Jimbe,
Thank you for replying, I was able to solve the problem.
Best,
Nelson
(3,115 Views)
Hello NES2112!
Could you please share how you solved it?
best
(3,112 Views)
