NI VISA Write Error on 64 bit application
Hi there,
I had recently trying to compile my working 32bit Labview application to 64bit since I want to try out the performance under 64bit OS. 32bit application is noticably slow on a 64bit OS.
Here is my problem: I am using VISA Write Function in the application and for some reason, I am getting errors back when I run the 64bit application but the same code run on 32bit application.
I tried NI VISA 5.4 & 14.0 but both throwing errors. Anything else I can do to eliminate the error here? Smiley Indifferent
Below are output from the NI IO Tracer:
32bit:
200.  VISA Write ("GPIB0::18::INSTR", "*IDN?")
Process ID: 0x000008E4         Thread ID: 0x000017FC
Start Time: 22:29:06.944       Call Duration 00:00:00.015
Status: 0 (VI_SUCCESS)
201.  VISA Get Attribute ("GPIB0::18::INSTR", 0xBFFF0002, "GPIB0::18::INSTR")
Start Time: 22:29:06.960       Call Duration 00:00:00.000
202.  VISA Get Attribute ("GPIB0::18::INSTR", 0x3FFF001A, 3000)
64bit:
9.  VISA Write ("GPIB0::18::INSTR", "*IDN?")
Process ID: 0x00000A74         Thread ID: 0x00001150
Start Time: 21:08:25.491       Call Duration 00:00:00.005
Status: 0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
10.  viParseRsrc (0x00001002, "GPIB0::18::INSTR", 1, 0)
Start Time: 21:08:25.496       Call Duration 00:00:00.001
Thanks!
Message 1 of 1
(4,091 Views)
