NI USB-GPIB-HS not recognized by LabVIEW 2013
We received a brand new NI USB-GPIB-HS today.
It is recognized in NI-MAX along with the 3 instruments connected.
Yet, in LabVIEW 2013 SP1 (32-bit) none of the instruments is recognized.
I drop a VISA resource control box onto a new blank VI. The dropdown shows no choices. not even the COM ports .
Is it because we have Tulip enabled?
Message 1 of 14
(5,981 Views)
Hello nyc,
1. Are you able to communicate successfully with your devices using NI MAX VISA Test Panels?
2. What is the version of NI-VISA that you are using?
3. Have you checked that the VISA resource name control is set to detect all instruments in LabVIEW? You can check this by right-clicking the control and selecting Select VISA Class>>I/O Session>>Instr
Nadine H.
Applications Engineer
Message 2 of 14
(5,940 Views)
@Queen_Nadine wrote:
Hello nyc,
1. Yes
2. NI-VISA 5.4.1
3. Yes; that is how it is set.
Message 3 of 14
(5,918 Views)
Hello nyc,
Could you try installing the latest NI-VISA driver, namely version 14.0?  You can find it here:
http://www.ni.com/download/ni-visa-14.0/4722/en/
Let me know if that resolves the unexpected behavior.
Nadine H.
Message 4 of 14
(5,862 Views)
Hello nyc,
Unfortunately, I am no longer working on that project.
I will keep this information in mind for the next time.
Message 5 of 14
(5,855 Views)
Hi there,
I am having a very similar problem trying to read a Lakeshore 340. I am using Labview 12 and have just updated o MAX 14.0.0f0. I am able to read ad write to he Lakeshores no problem in MAX owever when I look for the I/O session in the VI I get only the option for COM1 and LPT. Any help would be appreciated.
James
Message 6 of 14
(5,540 Views)
Hello James,
Could you try installing the newest NI-VISA driver as described above and let me know what the outcome is?
Nadine H.
Message 7 of 14
(5,499 Views)
Hi Nadine,
Thanks for geting back to me. I have updated to the lates NI-VISA driver and still have the same problem. I can read/write to both devices in MAX but they do not appear in the LabView VIs.
James
Message 8 of 14
(5,488 Views)
@JamesI15 wrote:
Hi Nadine,
James
I have since left the company where we were using the USB-GPIB-HS with LabVIEW 2013 32-bit. It was a big shock that it did not work. I had assured my manager that buying a NI adapter would be so much better experience than using the Agilent adapter. NOT.
I was going to try to see if LabVIEW 2014 32-bit solves the problem. You may want to download LabVIEW 2014. It is free to evaluate for 45 days.
Message 9 of 14
(5,479 Views)
Ah... see I am using an Agilent adapter... still not working... Everything can see them, talk to them and read from them except LabView itself...
Message 10 of 14
(5,476 Views)
