12-15-2004 08:55 PM
12-16-2004 08:04 AM
12-16-2004 10:40 AM
12-16-2004 09:04 PM
12-17-2004 10:00 AM
12-17-2004 01:12 PM
12-20-2004 11:56 AM
12-20-2004 09:05 PM
12-21-2004 05:29 PM
@jls wrote:
If possible, can you replicate the issue with a shortened network, and/or can you try sending and receiving 0xFF's only. The reason I ask, and I admit that I am reaching here, is that 0xAA = 10101010 which is causing "more" of the highest possible frequency component to exist in your frame (the frequency corresponding to your baud rate), whereas 0xFF = 11111111 does not force "as much" of this frequency. In general, those components should be most susceptible to transmission line effects. Taken together, I think shortening the network to reduce transmission line effects and/or sending "lower frequency data" would be interesting experiments to do given the nature of the phenomenon you observe.
I'm interested in any repost!
Thank you,
JLS
12-22-2004 07:59 AM
