01-06-2017 07:55 AM
Can anyone tell me if the NI PCIe-GPIB card is compatible with Windows 10 32 and 64 bit? The data sheet shows Windows Vista as the latest. Surely it is compatible with a later versiion then that.
01-09-2017 09:06 AM
The NI PCIe-GPIB card uses the driver NI-488.2, and the version 16.0.0: http://www.ni.com/download/ni-488.2-16.0.0/6132/en/ , is compatible with Windows 10 - 32 bit or 64 bit. You will have no compatibility problem using that card in a Windows 10 machine with the NI-488.2 version 16.0.0 driver.
03-14-2019 10:39 AM
Is the PCI-GPIB card also Windows 10 compatible?
