08-12-2014 05:08 PM
Hi all!
Is there a restriction in NI-MAX that only allows one remote system? I ask because my NI-MAX can only find one remote system out of the three remote systems I have. All four have NI-VISA server started. When I try to add it to the remote options, MAX tells me that it already exists as a MAX remote system.
Any help is appreciated.
Thanks!
08-13-2014 01:07 PM
Should find everything. How is it connected? For ethernet, is everything on the same subnet?
I've had to add remote systems manually before, since occasionally I'll need to talk to a machine in the lab or manufacturing floor that's on a different subnet than my workstation. Copy the IP, right-click and "create new", VISA system, key in the IP, and next-next-next-finish.
This assumes your network doesn't have firewalls between subnets (unlikely), or that those ports are open between network segments.
08-27-2014 02:07 PM
Snowmule,
Sorry for the late reply.
Everything is connected to the same network. I tried adding it manually and adding it as a visa system. When I tried adding it manually, it says that it's already a VISA system. My firewalls and ports are open between the networks, so I'm not sure what I'm missing here.
