02-09-2016 12:53 PM
Every time I start the NI MAX it freezes. At first it shows the splash screen and then attempts to establish a network connection (?).
After those changes, the NI MAX window freezes. It won't respond. I've been waiting for an hour or so and I had to kill the process.
I'm using the v15, two GPIBs (one of them brand new) and a PXI with the cards PXI-4070 and the 6341.
The same happens when I try to use VISA on LabVIEW, I select the "Open VISA" VI and when I try to add the "port" it freezes as well.
What is going on? I'm getting real dissapointed due to the value of the products that I have and none of them seem to work just fine.
I have Windows 7 Professional SP1. One of the GPIBs is attached to a Power Supply and the other one is attached to a multimeter Agilent 34401A.
I didn't mean to be rude, but it's getting really frustrating.
02-09-2016 01:18 PM
02-09-2016 02:32 PM
I had to restart the computer (because otherwise I will never be able to resetting the database), then I was able to reset the database. Now it's opening "correctly" , but it shows a message about an internal error:
And the interesting thing is that, when it shows one of these messages it works a little bit fine. But when it shows two of them, it freezes (is like the database is being corrupted again) and I don't know why. The last thing happened just after I closed the NI MAX and I didn't plug any device.
A few weeks ago I had the Error 1612.
Any other suggestion?
02-10-2016 10:38 AM
