Scott,
Perhaps the use of 'asserted' was not so good in this situation.
What I mean is that NRFD stays low after the NAT7210 has been addressed as listener. When I send the bytes to do this, everything is OK. So, there is no problem in sending the sequence UNL, MTA0, MLA7. Every time NRFD goes low for a short time, and then goes high again. After MLA7 however, NRFD does not go high and I have to write a rrfd command to the chip to have it release NRFD.
I hope this makes it clearer.
Rudie
