Burt,
at first I'd have a look at the resulting data rates, buffer sizes etc and estimate, if this fits into the capabilities of your machine and ports.
One needs the size of your single data (8 ch * 10 kHz * U8 is 80kB/s, whereas using Dbl one gets 640 kB/s). Tell us also the operating system your SW runs on (XP would occupy about 120-150 MB on your Crusoe board, so leaving just about 150-200 MB for LabVIEW, your code and your data). Depending of your code size this might become difficult.
Try to get some more data about your project and your code. In LabVIEW, press >Ctrl> and select 'memory usage'. This will give you the real numbers of your code. If you do this before you have started your code and after it has run and fallen behind its scheme, you have your data usage.
We'd need these numbers to give more detailled hints.
Greetings from Germany!
Uwe Frenz
