angs if not used for about 10 mins. Restart LV does not help. Have to either pull USB plug out of the port (I use USB-RS232 convertor) or restart the PC. Can I use to reset the port thru my aplication? Re-initialisation / clearing of buffers does not help.I am not sure if the problem is due to the USB port convertor or just that the CLOSE vi is not working right. The problem shows up only after longish periods of inactivity on the (closed) port.
