Modem vs Visa
I've my labview stand alone application that talks with an external device over RS232. The things go well with every kind of modem (analog or gsm type), but when i try to use the internal one (Pctel hsp56 MR data/fax), although the same parameters settings ( no flow control hard&software beyond the same AT parameters setting, i hope! ) when i run Visa close, the modem hang up. The same thing does not occurs when i use others modems with the same code. Has someone idea of the AT command that is related to Visa close?
Thanks for your attention,
Have a good code.
Chyrus
(2,888 Views)
AFAIK there is no relation. Those two commands are on different layers of the protocol. AT-commands are issued using VISA.
I'd suspect some default settings made by VISA at close with some of the flow control lines. You may try to use NI-SPY to look for such. As this is an internal (and maybe even virtual) modem you may not be abel to measure the flow control line levels.
Greetings from Germany!
Uwe
(2,880 Views)
