I've my labview stand alone application that talks with an external device over RS232. The things go well with every kind of modem (analog or gsm type), but when i try to use the internal one (Pctel hsp56 MR data/fax), although the same parameters settings ( no flow control hard&software beyond the same AT parameters setting, i hope! ) when i run Visa close, the modem hang up. The same thing does not occurs when i use others modems with the same code. Has someone idea of the AT command that is related to Visa close?
Thanks for your attention,
Have a good code.
Chyrus
