04-12-2016 08:14 AM
Thank you very much but one sub-VI is missing "Msec timer". Could you send me too pls ? 😄
04-13-2016 01:31 AM
04-13-2016 10:18 AM
Apparently, this VI works but it doesn't transmit any datas. However, this VI is great and fix a visa problem that I have because I don't receive -1073807298 error code with visa read or write. (1073676294 meaning that we received the same bits number that we had sent)
In conclusion, communication is good but no datas are transmitted with the USB cable ? (I'll try to make the communication with a RS232 cable as soon as I receive the serial pinout of the bench)
04-14-2016 01:42 AM
You say 'No data transmitted'
Well since the ModBus command is OK there is data transmitted (the ModBus comamnd) and data received (the ModBus answer)
Which ModBus lib are you using ? Can you post it here ?
Kees
04-14-2016 04:59 AM
Finally it worked !!! I am using different labraries, and among them is the most common modbus library, and the plasmionique modbus library that you can find in the link below :
https://lavag.org/topic/19544-cr-plasmionique-modbus-master/
Last time I ran the Plasmionique Com Tester, I forgot to also run "MB slave example"... (no comment 😛 )
Thank you KC for you help anyway 🙂
04-14-2016 04:15 PM
hi all, more informations here
A+ Luc
Luc Desruelle | Mon profil | Mon blog LabVIEW | Auteur livre LabVIEW : Programmation et applications - G Web
Certified LabVIEW Architect (CLA) & Certified TestStand Developper (CTD) | LabVIEW Champion
MESULOG - LinkedIn site | NERYS - NERYS Group
| directeur CEO MESULOG
| CODIR - NERYS group
