Hello Kevin,
There is no specific disadvantage of using 1.7 over version 2.2 and some changes that were made in NI 488.2 v2.2 are mentioned in the v2.2 'Readme' file: http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/e269bd7f280e068986256e9700660397?OpenDocument (not necessarily above v1.7, but above some other versions like 2.0 or 2.1). I'd highly encourage you to use version 2.2 since it is the latest version and also it is going to work perfectly fine in your software (as previously discussed, the issue is with MAX only and while doing 'Scan for Instruments' only), and even in MAX, you should be able to test the instrument using ibic
. Also another advantage of 2.2 is that, since you already have v2.2 on your current machine, you do not have to uninstall 2.2 and then install 1.7 😉
Good luck with your application!
Swapnil P.
National Instruments Engineer
