Loop Problem !
Dear Friends,
I need to do a loop which increaments the Voltage part of my string ( please check the picture for it ! ) I want my power supply to increment its output with its commands.
But since the string is not a value i just can`t manage to do this loop...
help...
With Best Regards
Message Edited by Support on 11-13-2007 12:59 PM
(2,876 Views)
What you need is a shift register with a numeric and then convert that to a string. With a while loop, increment the number each iteration and terminate the while loop when your max value is reached. I've attached a picture of an example. Please also note that I've attached a jpeg file. Bmp files take too long to download. MS Paint gives you the ability to save bmp files as jpg.
(2,866 Views)
