When an interface controller board is setup as a listen only mode, how is it possible to know when a talker is 'online' and desiring to send information. In a normal situation, you could monitor ibsta by using ibwait(ud,0) to get the status of ibsta, and when the interface board was addressed as a listener, you could go ahead and process the request. Since the IB is configured as a Lonly, this doesn't happen. I am at loss as to how and handle this. Would a talker only istrument typically signal in some other way? Thanks for any help.. Jim
