06-26-2014 03:59 AM
I’m developing a GUI with Qt to control some oscilloscopes from LeCroy. For communication via Ethernet I want to use the VISA library.
I’ve written some code to test the communication channel but it just won’t compile. Here a short list of what I’ve already tried to make it run:
- copied project to C:\Temp to avoid space problems within the path
- used visa32.lib and visa64.lib
- copied libraries to the project folder
- linked libraries static and dynamic
The result or the copied library into the project folder is:
Fehler: No rule to make target 'C:/path…', needed by 'debug\KommunikationOszi3.exe'. Stop.
And the result with the “original” library is:
Fehler: error: Files/IVI: No such file or directory
Fehler: error: Foundation/VISA/Win64/Lib_x64/msc/: No such file or directory
The link commands in the project files are:
lib within project folder
win32: LIBS += -L$$PWD/ -lvisa32 INCLUDEPATH += $$PWD/ DEPENDPATH += $$PWD/
lib in the original folder:
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc/ -lvisa32 else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc/ -lvisa32d INCLUDEPATH += $$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc DEPENDPATH += $$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc
And some code examples from my program:
Header file of the oscilloscope class
#ifndef LECROYWAVESURFER_H #define LECROYWAVESURFER_H #include <string> #include <sstream> #include <iomanip> #include "visa.h" class LeCroyWavesurfer { public: LeCroyWavesurfer(ViSession *defaultRM, std::string name = "", std::string ip = "0.0.0.0"); ~LeCroyWavesurfer(); // communication functions void write(std::string command, std::string logMsg); std::string read(std::string command, std::string logMsg, ViUInt32 datLength); // configuring oscilloskop void autoSetup(std::string channel); private: std::string name; // for VISA-communication ViSession *defaultRM; // connection to main VISA driver ViSession session; // connection to device ViStatus status; // communication status ViUInt32 retCount; // retur count from string I/O }; #endif // LECROYWAVESURFER_H
Some extracts frome the CPP file of the oscilloscope class
#include "leCroyWavesurfer.h" /***************************************************************************************/ // Includes for code completion /***************************************************************************************/ #include <QDebug> /****************************************************************************************/ // Constructor /****************************************************************************************/ LeCroyWavesurfer::LeCroyWavesurfer(ViSession *defaultRM, std::string name, std::string ip) { this->name = name; this->defaultRM = defaultRM; qDebug() << "Connection to Wafesurfer" << name.c_str(); std::string geraet = "VICP::" + ip; status = viOpen(*defaultRM, (ViRsrc)geraet.c_str(), VI_NULL, VI_NULL, &session); if (status < VI_SUCCESS) qDebug() << "Connecting to" << name.c_str() << "failed"; qDebug() << "Setting time out for communication with" << name.c_str(); status = viSetAttribute(session, VI_ATTR_TMO_VALUE, 500); if (status < VI_SUCCESS) qDebug() << "Setting time out failed"; } /****************************************************************************************/ // Destructor /****************************************************************************************/ LeCroyWavesurfer::~LeCroyWavesurfer() { qDebug() << "Disconnecting from" << name.c_str(); status = viClose(session); if (status < VI_SUCCESS) qDebug() << "Disconnecting from" << name.c_str() << "failed"; delete this; } /****************************************************************************************/ // Writing command to oscilloscope /****************************************************************************************/ void LeCroyWavesurfer::write(std::string command, std::string logMsg) { // creating log message for debugging qDebug() << logMsg.c_str(); qDebug() << "Sent command:" << command.c_str(); status = viWrite(session, (ViBuf)command.c_str(), command.length(), &retCount); if (status < VI_SUCCESS) qDebug() << logMsg.c_str() << "failed"; } /****************************************************************************************/ // activating auto setup for chosen channel /****************************************************************************************/ void LeCroyWavesurfer::autoSetup(std::string channel) { // command syntax: <channel> : Auto_SETup [FIND] // <channel> : = {C1, C2, C3, C4} // If the FIND keyword is present, gain and offset adjustments will be performed // only on the specified channel. // In the absence of the FIND keyword, the normal auto-setup will be performed, // regardless of the <channel> prefix. std::string command = "C" + channel + " : Auto_SETup FIND"; std::string logMsg = "Setting auto setup for channel " + channel; write(command,logMsg); }
Qt 5.2.1 runs under Win7. I have a user account not an admin account.
Does anyone know how to fix this problem?
Solved! Go to Solution.
07-24-2014 05:39 AM
I don't know why, but with a direct path it works. Should look like this:
# Library for VISA functions win32: LIBS += "C:/Program Files (x86)/IVI Foundation/VISA/WinNT/lib/msc/visa32.lib"
If you also add the include folder you don't need to copy the visa.h into your project folder.
INCLUDEPATH += "C:/Program Files/IVI Foundation/VISA/Win64/Include" DEPENDPATH += "C:/Program Files/IVI Foundation/VISA/Win64/Include"
04-03-2023 06:59 AM
BRO you saved me XD
