11-04-2014 01:55 PM
Greetings,
I have two LS-211 that I am getting a timeout on the VISA read from. The curious thing is that they work fine in MAX with IDN?\n however when I open a VISA session and preform the write and read (write with term charactors CR/LF appended) the read times out. I get the same behavior from my 121's and my Keithly 2200. I am first trying to deal with the 211's first. Any ideas why it works on MAX and not with VISA?
Solved! Go to Solution.
11-04-2014 02:11 PM
11-05-2014 07:22 AM
Thanks for the input but the good news is that I was able to get the 211 working when I queried temperature but it does not seem to work for IDN?. Matters not since temp is what I am interested in.
The issue I am having now is with the 121. It times out on both MAX and the vi which is attached. I am using a 8430/8 RS232 and a USB to DBN cable converter to adapt to the USB connection. I assume that when doing this a straight through 232 cable is required and not a null cable. The reason why I ask is that I am doing the same on my Keithleys and they also have the same behavior.
11-05-2014 01:49 PM
11-06-2014 01:39 PM
Yes that is what I was doing. Once I switched to USB all of my comm issues were resolved. Live and learn...
11-06-2014 02:15 PM
11-06-2014 04:07 PM
Pretty pathetic choosing your own post as the solution.
11-07-2014 06:13 AM
Sorry guys my mistake. Knutsons solution was the one I should have posted as a solution.
11-07-2014 08:04 AM
11-07-2014 08:17 AM - edited 11-07-2014 08:18 AM
You did it! The correct solution is marked. 🙂
