03-28-2006 11:51 AM
03-28-2006 11:58 AM
03-28-2006 12:07 PM
Thanks Dennis, I downloaded the drivers. Will keep you posted after trying it with the instrument. Thanks once again.
Sincerest Regards,
Manoj Narayanan
03-29-2006 11:47 AM
03-29-2006 11:09 PM
Hi Brain,
I measure the impedance & phase or Cp & D for my samples at different frequency ranges. I can do all the calibration and settings from the front panel. All I need is, once I am done with the frequency sweep fro my experiment, I want the program to grab the data from the LCD screen and put it into a excel sheet or a txt file. WHat i do now is once i am done with the frequency sweep, I have to note down the readings by hand which is very time consuming. Please let me know.
Thanks a lot.
Sincerest Regards,
Manoj
03-30-2006 06:22 AM
05-22-2006 10:14 AM
Hey Brian,
I am glad I found this thread with your example vi's for the HP 4194A. It was of great help and the program worked like a charm. I would also to like output Cs-Rs along with the impedance as a function of frequency and was wondering if you could guide me to do that using your program.
Thanks once again
Pradip
05-22-2006 11:14 AM
Pradip-
You just basically change the settings for the cap sweep, then get the array data. The program I supplied gets cap and dis data from 900 to 1000 Hz over 10 points. Change those parameters to get what you want. You will also need to not assign variables to the array A locations. Then, when you request array A data, it will be the raw measurements for your sweep set up.
05-22-2006 01:18 PM
Hey Brian
Thanks a lot for the quick response. The program you supplied through this thread does a default 500-600 kHz sweep for the impedance and outputs it to a spread-sheet and even plots it to the main vi. I am using labview for the first time, and I am trying to find where I can change the settings for the capacitance scan and output that as an array in your program. Also, do i need to make any changes in the subVIs to do a capacitance scan.
Many thanks,
Pradip
05-23-2006 11:49 AM
I don't have the instrument's manual, or even the instrument, anymore. I suggest that you become familiar with the parameters that are available to use. They are the same that are available over comms, but they are worded a little differently. Most things are documented in the manual.
My program does a cap sweep. It is only 10 points though. Study the program, step through it and watch what the instrument does as you step through it.
