05-05-2014 07:11 PM
I am having problems connecting to a Kepco SNR 488-8 Power Controller via the GPIB bus. The odd thing is that I was able to connect to it before...
Here are the steps to reproduce the error:
This is what I've tried to fix the error:
I had the Agilent VISA installed at one point, but I uninstalled it so the NI VISA should be the only one left.
Is there anything else I can try?
Thank you,
Graham Best
05-05-2014 07:35 PM
05-07-2014 05:36 PM
The version of NI-488.2 is 3.1.1.
I was able to connect to another test equipment device. I also tried to connect to another Kepco SNR 488-8 power controller and had the same issue. Both of these units are functional when they are connected to a much older computer.
05-07-2014 06:44 PM
05-07-2014 07:17 PM
I tried changing the bus timing from 500 nanoseconds to 2 microseconds and the instrument was still not recognized.
