10-09-2014 02:48 PM
10-10-2014 12:51 AM
Thank you for your reply. I tried Keithley 24XX Output List and Acquire.vi , but when I run the file there are errors as: Sub VI is missing. is there any way to solve this?
10-10-2014 01:50 AM
Is your NI Software up to date? I had the same problem once and I used the NI Update Service to update the Software.
Which SubVIs are missing?
10-10-2014 06:21 AM - edited 10-10-2014 06:24 AM
Sub VI missing is solved ba replacing the file. When I run the keithley 24xx output list and acquire.vi i have an error. you can see in attached file.
10-10-2014 02:40 PM
The error is that you ask something from the K2400 that is not allowed.
Could it be that the combination of 0.1 Amp compliance and 0.1 Volt is not allowed?
What is the Voltage limit?
It is possibkle that the order in which the limits and source voltage is programmed generate such an error,
What vi did you replace?
In my system the example loaded without errors
10-13-2014 01:57 AM
First, the examples did not run because of wrong path directory . Hence I saved Keithley 24xx in instr.lib of labview 2013 . I chose current rang as 1 mA and voltage limit as 1 mV.
10-13-2014 02:41 AM
I'm a bit confused about using Labview with Keithley 2400. Does it need to send any command through communicator to keithley240xx ?
Because I thought , I just have to connect the keithley to my laptop and then run the Labview.
10-13-2014 03:12 AM
10-13-2014 12:01 PM
01-07-2015 09:23 AM
Hello People,
I am having the problem with the keythley 2400 sourcemeter. While working or measuring my solar devices this instrument is getting turned off and i have to switch it on again to work. Please suggest some solution...having hard time resolving it. 😞
