Issues with adjusting GPIB Bus Timing
Hi Everyone
I want to change my GPIB bus timing and HS-488 cable length  but I have issues doing so in NI-MAX using windows 7 64bit.
I think this is due to administrator access rights, but all the setting for the GPIB controller are grayed out and I can not adjust them.
I currently have the newest max, visa 14.0, gpib 140.0 and labview 2014  installed.
Does anyone know what priviallges I need to adjust these setting?
Is there any INI file or register setting I can modify to adjust these settings?
(4,289 Views)
indeed an admin's rights problem.
ask your IT department to solve this. They are the ones not granting you access so blame them.
greetings from the Netherlands
(4,273 Views)
