On Sat, 17 Jan 2004 11:18:32 -0600, Face wrote:
> I knew that it is possible to connenct two identical instruments by one
> GPIB board.
> But I met the following problem?
> I connect two identical oscilloscope to one GPIB board in one
> computer,but When I use Visa Find Resources.vi, It only display one GPIB
> adress(GPIB0::1) How can I to distinguish these two oscilloscope? Do I
> need use second address?
> I am not sure how to configure these? Thanks!
Yep, you need to set the address for the other instrument. With newer
instruments you can use the buttons on the front panel to set the address.
On older instruments, like the ones I have, you need to set a row of
switches, usually located on the rear panel. Just make sure each
instrument has a uniqu
e address and it should work.
