05-12-2017 04:57 AM
I would like to compare two logs recorded with NI IO Trace side by side, but it seems I am not able to start two independent instances of the tool. Am I missing something or is it really so that only one instance can run at a time? And why is that so?
Thanks in advance for any reply.
05-23-2017 05:59 AM
Hey Juanton,
Unfortunately, it is not possible to run them in parallel. But since the report is a readable ASCII text file if you save it. You can use for example notepad++ with the compare plugin. This toll would even highlightz the differences between 2 reports.
Kind regards
05-24-2017 01:41 AM
Hi HeinzG.,
thanks a lot for your answer.
Unfortunately, the readable ASCII file generated from File >> Export... has some drawbacks:
- It produces quite some (for my purpose) undesired overhead, which makes it unusable for Notepad++ comparisons as e.g. the time stamps will all be flagged as differences.
- It truncates the SCPI commands/responses (this is critical!).
Looks like I'll have to live up to not being able to do direct comparisons ...?
Best regards
05-24-2017 01:57 AM
Hey,
hmmm...
at least the timestamps you could remove with a simple VI before comparing.
Kind regards
Heinz
05-24-2017 03:19 AM
that would probably be one first step.
I think we better drop it here.
Thanks for your efforts and best regards
Juan
