06-22-2015 09:11 AM
Hey
I am converting SR830 lock in amplifier from GPIB to serial config,for which i have added Visa in the main Vi.
With this when i run the vi,Query Instrument Id always fails.
So i disabled it and reading only the ID without checking if its right.When i do this,i get Error 1073807343.
I wanna know if i have to take the serial config even within the initiazi vi,if so how??
06-22-2015 09:23 AM
My guess is that you have a serial port configuration mismatch. You should just use the Configure Serial Port instead of the VISA Open and make sure all of your settings match what the instrument has.
06-22-2015 09:29 AM
I am using Configure Serial Port to which VISA OPEN is given along with other setting.This is done in main vi,should i do that in INitialize vi too,if so how??
06-22-2015 09:34 AM
06-22-2015 09:42 AM
I have already refered 34401,it has only serial support not GPIB.
I added serail config to Initialize vi and removed it from main vi,even then it throws error.
06-22-2015 09:59 AM
06-22-2015 10:02 AM
06-22-2015 10:05 AM
Rude and totaly UNPROFESSIONAL.
1st understand what my question is and answer to it.What do u mean by "Why bother using VISA in that case? " am already using it.
it is silly that people who lack knowledge are answering to the client queries.
Let someone who has knowledge to solve this answer.
06-22-2015 10:06 AM
Termination char is taken care.1st check in all the pics i have shared
06-22-2015 10:16 AM
