Equipment: Agilent 54615B O-Scope, HP 54503A O-Scope
Problem: When using the E5810 LAN/GPIB Gateway to access the o-scopes through LABView VIs, they don't respond well to the ID query. Although when directly talking to the devices using the web-enabled interface, i can query the instruments and send them instructions manually; however, using the VI supplied by the development zone for the agilent 546xx series o-scopes, neither will respond. I might see why the HP Scope wouldn't cooperate (although they speak the same language), it's hard to imagine why the Agilent O-scope won't work, especially when a similar scope, the 54622D works well with all of the supplied VIs. Can anyone provide insight on how to handle the Invalid ID query or at least get around it?
Odene
